US8419919B1 - System and method for generating particles - Google Patents
System and method for generating particles Download PDFInfo
- Publication number
- US8419919B1 US8419919B1 US11/859,499 US85949907A US8419919B1 US 8419919 B1 US8419919 B1 US 8419919B1 US 85949907 A US85949907 A US 85949907A US 8419919 B1 US8419919 B1 US 8419919B1
- Authority
- US
- United States
- Prior art keywords
- cathode
- anode
- current
- supplying
- time period
- Prior art date
- Legal status (The legal status is an assumption and is not a legal conclusion. Google has not performed a legal analysis and makes no representation as to the accuracy of the status listed.)
- Active, expires
Links
Images
Classifications
- C—CHEMISTRY; METALLURGY
- C25—ELECTROLYTIC OR ELECTROPHORETIC PROCESSES; APPARATUS THEREFOR
- C25C—PROCESSES FOR THE ELECTROLYTIC PRODUCTION, RECOVERY OR REFINING OF METALS; APPARATUS THEREFOR
- C25C1/00—Electrolytic production, recovery or refining of metals by electrolysis of solutions
- C25C1/20—Electrolytic production, recovery or refining of metals by electrolysis of solutions of noble metals
- C25C5/00—Electrolytic production, recovery or refining of metal powders or porous metal masses
- C25C5/02—Electrolytic production, recovery or refining of metal powders or porous metal masses from solutions
- C25C7/00—Constructional parts, or assemblies thereof, of cells; Servicing or operating of cells
Definitions
- the embodiments of the invention relate generally to the field of electrochemistry.
- Generated particles may be captured by other nuclei to create new elements, to remediate nuclear waste, to treat cancerous tumors, or to create strategic materials. Previous efforts to create a reproducible method and corresponding system to generate particles during electrolysis of palladium in heavy water have been unsuccessful.
- FIG. 1 illustrates a flow chart of an implementation of a method for generating particles.
- FIG. 2 illustrates a flow chart of an implementation of a first charging profile for an implementation of the method for generating particles.
- FIG. 3 illustrates a flow chart of an implementation of a second charging profile for an implementation of the method for generating particles.
- FIG. 4 illustrates a front perspective view of an embodiment of a system for generating particles using an external magnetic field.
- FIG. 5 illustrates a cross-section view of an embodiment of a system for generating particles using an external magnetic field, during a co-deposition process.
- FIG. 6 illustrates a cross-section view of an embodiment of a system for generating particles using an external electric field
- FIG. 7A illustrates a front view of one side of an embodiment of a system for generating particles using an external magnetic field, illustrating an embodiment of the cathode.
- FIG. 7B illustrates a front view of one side of an embodiment of a system for generating particles using an external magnetic field, illustrating an embodiment of the cathode.
- FIG. 7C illustrates a front view of one side of an embodiment of a system for generating particles using an external magnetic field, illustrating an embodiment of the cathode.
- FIGS. 8A and 8B show images of alpha particle tracks in a CR-39 detector, where the microscope optics are focused on the surface of the detector and the bottom of the pits, respectively.
- FIGS. 8C and 8D show images of Pd/D co-deposition generated tracks in a CR-39 detector, where the microscope optics are focused on the surface of the detector and the bottom of the pits, respectively.
- FIGS. 9A and 9B show images taken of the CR-39 detector after a Pd/D co-deposition experiment in a magnetic field.
- FIG. 10A shows features observed when a CR-39 detector is exposed to depleted Uranium.
- FIG. 10B shows features observed when a CR-39 detector has undergone exposure to a Pd/D co-deposition experiment in the presence of an external electric field.
- FIG. 11 illustrates an image of a CR-39 detector indicating X-ray emission, in accordance with an embodiment of the system and method for generating particles.
- FIG. 12A shows an image taken of a CR-39 detector after a Pd/D co-deposition experiment on a Ni screen cathode in the presence of a magnetic field.
- FIG. 12B shows an image of a CR-39 detector after a Pd/D co-deposition experiment on a Ni/Au composite cathode in which Au is a high Z material.
- FIG. 13A shows an SEM of the Pd deposit obtained on a Au foil cathode in a magnetic field experiment.
- FIGS. 13B-13D show images taken of a CR-39 detector after a Pd/D co-deposition experiment in a magnetic field using a Ag wire cathode.
- FIG. 1 shows a flow chart of an implementation of a method for generating particles 10 .
- One implementation of method 10 may utilize an electrochemical cell 100 as shown in FIGS. 4 and 5 . As such, method 10 will be discussed with reference to electrochemical cell 100 .
- Method 10 may be performed at conditions of ambient temperature and standard atmospheric pressure.
- Method 10 may begin at step 20 , where a current may be supplied to the electrodes of an electrochemical cell according to a first charging profile.
- step 20 may involve supplying current to the positive electrode, anode 130 , and the negative electrode, cathode 132 , of electrochemical cell 100 .
- Step 20 may be discussed in further detail with regard to FIG. 2 .
- method 10 may proceed to step 30 .
- Step 30 may involve maintaining a generally constant current between the positive and negative electrodes during the first charging profile such that deposition of metal 172 on the cathode occurs in the presence of evolving deuterium gas during electrolysis of an electrolytic solution.
- step 30 may involve maintaining a generally constant current between the anode 130 and cathode 132 during the first charging profile.
- Step 30 may be performed by connecting a galvanostat/potentiostat 140 to anode 130 and cathode 132 .
- Step 40 may be performed by positioning magnets 160 and 162 opposite one another on opposing sides of electrochemical cell 100 (see FIGS. 4 and 5 ). Step 40 may occur during the deposition of the metal on the cathode. In other embodiments, step 40 may occur after the termination of the deposition of the metal on the cathode.
- the determination that the deposition of the metal on the cathode has terminated may be made by a visual inspection that the plating solution within electrolytic solution 170 has turned from a red-brown color to clear. The plating solution turns clear when metal has all been plated onto cathode 132 .
- Method 10 may then proceed to step 50 , where a current may be supplied to the electrodes according to a second charging profile during the exposure of the electrochemical cell to the external field.
- step 50 may involve using a power source to supply a current to anode 130 and cathode 132 according to a second charging profile during the exposure of electrochemical cell 100 to an external magnetic field (not shown).
- Particles are generated from the application of method 10 .
- the term “generated” is used to refer to the forming of particles through a process involving chemical and, depending upon the substrate, magnetic interaction. Examples of the types of particles generated and detected may include, but are not limited to: alpha particles, beta particles, gamma rays, energetic protons, deuterons, tritons, and neutrons.
- the particles generated by the implementations of method 10 may have various applications. For example, the generated particles may be captured by other nuclei to create new elements, may be used to remediate nuclear waste, may be used to create strategic materials, or may be used to treat cancerous tumors.
- FIG. 2 shows a flow chart of an implementation of step 20 of method 10 .
- Step 20 may include more than one current level and more than one time period, wherein each of the current levels is supplied across the anode and the cathode for one of the time periods.
- Step 20 may be performed to assure good adherence of the palladium, a deuterium absorbing metal, to cathode 132 , which may be a wire having a length of 2 cm and a diameter of 0.5 cm.
- Step 20 may involve low current densities for adhering the palladium to cathode 132 .
- step 20 may begin at step 22 , where a reducing current of 100 ⁇ A may be supplied to the anode and cathode for a time period of about twenty-four hours.
- step 24 may involve supplying a reducing current of 200 ⁇ A to anode 130 and cathode 132 for a time period of about forty-eight hours.
- Step 20 may then proceed to step 26 , where a reducing current of 500 ⁇ A may be supplied to anode 130 and cathode 132 until the completion of the deposition process.
- the completion of the deposition process will occur when the plating solution appears clear as described above.
- the amount of time required for the completion of the deposition process may be between approximately 3 and 7 days, depending upon the surface area of cathode 132 and the first charging profile used.
- Electrochemical reactions occurring at the cathode include: Pd 2+ +2 e ⁇ Pd 0 D 2 O+ e ⁇ D 0 ⁇ OD ⁇ (Eq. 1)
- the D 0 is either absorbed by the Pd or binds to another D 0 to form a deuterium molecule, D 2 .
- D 2 is a gas. The result is that metallic Pd is deposited on the cathode in the presence of evolving D 2 .
- FIG. 3 illustrates a flow chart of an implementation of step 50 of method 10 .
- Step 50 may be performed to load metal 172 on cathode 132 with deuterium.
- step 50 may involve more than one current levels and more than one time periods, wherein each of the current levels is supplied across the anode and the cathode for one of the time periods.
- step 50 may involve levels of increasing current density to load the palladium lattice with deuterium such that the ratio of deuterium to palladium is ⁇ 1.
- one implementation of step 50 may begin at step 52 , where a current of 1 mA is supplied to anode 130 and cathode 132 for a time period of about two hours.
- step 54 may involve supplying a current of 2 mA to anode 130 and cathode 132 for a time period of about six hours.
- step 56 may involve supplying a current of 5 mA to anode 130 and cathode 132 for a time period of about twenty-four hours.
- step 58 may involve supplying a current of 10 mA to anode 130 and cathode 132 for a time period of about twenty-four hours.
- step 60 may involve supplying a current of 25 mA to anode 130 and cathode 132 for a time period of about twenty-four hours.
- step 62 may involve supplying a current of 50 mA to anode 130 and cathode 132 for a time period of about twenty-four hours.
- step 64 may involve supplying a current of 75 mA to anode 130 and cathode 132 for a time period of about twenty-four hours.
- step 66 may involve supplying a current of 100 mA to anode 130 and cathode 132 for a time period of about twenty-four hours.
- electrochemical cell 100 may include an electrolytic solution 170 , an anode 130 , and a cathode 132 .
- Electrolytic solution 170 may comprise a metallic salt having a first metal that substantially absorbs deuterium when reduced to an atomic state, and a supporting electrolyte, each dissolved in heavy water.
- the metallic salt may be selected from the group of transition metals, such as palladium.
- the reduced metal 172 such as palladium, absorbs deuterium 174 .
- electrolytic solution 170 comprises 20-25 mL solution of 0.03 M palladium chloride and 0.3 M lithium chloride in deuterated water.
- Cathode 132 may be partially immersed in electrolytic solution 170 .
- Cathode 132 may comprise a second metal that does not substantially absorb deuterium 174 and is generally stable in electrolytic solution 170 when cathode 132 is polarized.
- cathode 132 may be comprised of Au, Ag, Pt, as well as their alloys.
- cathode 132 may comprise a second metal that does absorb deuterium 174 and is generally stable in electrolytic solution 170 when cathode 132 is polarized.
- cathode 132 may be comprised of Ni or its alloys.
- Cathode 132 may be formed into various shapes, such as a wire, rod, screen, or foil.
- cathode 132 may be shaped as a wire having a diameter of 0.25 mm and a length of 2.5 cm.
- Anode 130 may also be partially immersed in electrolytic solution 170 and may be stable in electrolytic solution 170 when anode 130 is polarized.
- Anode 130 may be manufactured from any electrically conductive material which is stable in electrolytic solution 170 , such as Pt, as well as their alloys.
- the term “stable” with reference to anode 130 and cathode 132 means that the materials employed in the construction of anode 130 and cathode 132 do not substantially corrode when they are polarized and generally do not react with the electrolyte or products of electrolysis.
- Anode 130 may be formed into various shapes, such as a wire, rod, screen, or foil. As an example, anode 130 may be shaped as a wire having a diameter of 0.25 mm and a length of 30 cm.
- FIG. 4 illustrates a front perspective view of an embodiment of a system 100 for generating particles using an external magnetic field.
- System 100 may include an electrochemical cell 110 , power supply 140 , and magnets 160 .
- Cell 110 may include a body portion 120 and a top portion 122 .
- Cell 110 may be rectangular, square, cylindrical, cubical, or various other shapes as recognized in the art.
- Cell 110 an example of which is commercially available from Ridout Plastics, model AMAC, part number 752, may be comprised of various non-metallic materials that do not react with the electrolyte, such as butyrate.
- Body portion 120 may be configured to contain an electrolytic solution 170 (see FIG. 5 ).
- body portion 120 may be cubic in shape and may be comprised of a non-conductive material, such as plastic.
- Top portion 122 may be configured to cover body portion 120 .
- Top portion 120 may be comprised of a non-conductive material, such as plastic.
- Top portion 122 may contain an opening 124 therein where an anode 130 may be passed therethrough, and also an opening 126 where a cathode 132 may be passed therethrough.
- Top portion 122 may also contain an opening 128 for venting purposes.
- Anode 130 may comprise a wire mounted on a support 150 and may be partially immersed in electrolytic solution 170 (see FIG. 5 ).
- Support 150 may be comprised of a chemically inert material, such as polyethylene.
- Cathode 132 may be shaped as a single wire (as shown in FIG. 7A ), a screen (as shown in FIG. 7B ), or a foil (as shown in FIG. 7C ).
- One end 131 of anode 130 may be connected to power supply 140 .
- One end 133 of cathode 132 may be connected to power supply 140 .
- Power supply 140 may be a potentiostat/galvanostat, an example of which is commercially available from Princeton Applied Research, model 363.
- the other end 135 of anode 130 may be coupled to a support 150 (see FIG. 5 ), which may be secured to body portion 120 .
- Cathode 132 may be coupled to a particle detector 152 that may be attached to body portion 120 . Both particle detector 152 and cathode 132 may be mounted to body portion 120 .
- particle detector 152 may be contiguous with cathode 132 .
- detector 152 may be in proximity to cathode 132 , such that particles emitted from cathode 132 may contact particle detector 152 .
- particle detector 152 may be positioned adjacent to cathode 132 .
- particle detector 152 may be positioned between cathode 132 and body portion 120 .
- Particle detector 152 may be used to detect the occurrence of particles.
- Particle detector 152 may be comprised of a non-metallic material.
- particle detector 152 may be comprised of CR-39 material.
- CR-39 is a thermoset resin that is chemically resistant to the electrolyte and to electromagnetic noise.
- CR-39 may be commercially obtained from Landauer.
- Particle detector 152 may comprise various shapes. As an example, particle detector 152 may be rectangular in shape with dimensions of 1 cm ⁇ 2 cm ⁇ 1 mm.
- the size, depth of penetration, and shape of the tracks provides information about the mass, charge, energy, and direction of motion of particles generated by method 10 .
- Neutral particles like neutrons, will produce knock-ons, or charged particles resulting from the collision with the neutron that will leave ionization tracks, or, with sufficient energy (e.g. >12 MeV) cause 12 C present in the CR-39 resin to fission into 3 charged ⁇ particles that will leave ionization tracks.
- Magnets 160 and 162 may be positioned adjacent to body portion 120 such that a magnetic field is created within electrochemical cell 100 between anode 130 and cathode 132 and though electrolytic solution 170 . In some embodiments, the magnetic field created between magnets 160 and 162 may be sufficient to hold magnets 160 and 162 in position adjacent to body portion 120 . In other embodiments, magnets 160 and 162 may be attached to body portion 120 . Magnet 160 may be positioned adjacent to the surface of body portion 120 that contacts support 150 . Magnet 162 may be positioned adjacent to the surface of body portion 120 that contacts detector 152 . Magnets 160 and 162 may be comprised of various magnetic materials, such as NeFeB.
- magnets 160 and 162 may be 1 in ⁇ 1 in ⁇ 0.25 in. Magnets 160 and 162 may be commercially obtained from Dura Magnetics, part number NS-10010025. As an example, the external magnetic field created by magnets 160 and 162 may have a magnetic flux between about 1800 and 2200 Gauss. Magnets 160 and 162 may be permanent magnets or may be electromagnets.
- FIG. 5 illustrates a cross-section view of a cell 110 during a co-deposition process.
- cell 110 is connected to power supply 140 and includes electrolytic solution 170 therein.
- Electrolytic solution 170 may comprise a soluble metallic salt (not shown) having a first metal, such as palladium, and a supporting electrolyte (not shown), wherein the palladium and chlorine are combined to form a palladium chloride complex anion, PdCl 4 ⁇ .
- the palladium chloride complex anion may be dissolved in heavy water (D 2 O) (not shown), with the palladium absorbing deuterium 174 when in a reduced state.
- the supporting electrolyte may include an ionizable salt to increase solution conductivity.
- electrolytic solution 170 may be comprised of a metallic salt such as 0.05 M PdCl 2 and a salt such as 0.3 M LiCl dissolved in 99.9 percent pure heavy water.
- metal 172 infused with deuterium 174 may be deposited on cathode 132 , while oxygen 176 accumulates around anode 130 .
- FIG. 6 illustrates a cross-section view of an embodiment of a system 200 for generating particles using an external electric field.
- System 200 may include an electrochemical cell 210 , power supply 240 , and external electrodes 260 and 262 .
- Cell 210 may include a body portion 220 and a top portion 222 .
- Top portion may contain an opening 224 (not shown) therein where an anode 230 may be passed there through, and also an opening 226 (not shown) where a cathode 232 may be passed there through.
- Top portion 222 may also contain an opening 228 (not shown) for venting purposes.
- Cell 210 may be rectangular, square, cylindrical, or various other shapes as recognized in the art. Cell 210 may be comprised of various non-metallic materials, such as butyrate.
- Anode 230 and cathode 232 may be connected to power supply 240 .
- Power supply 240 may be a potentiostat or a galvanostat.
- Anode 230 is attached to a support 250 .
- Cathode 232 may be coupled to a particle detector 254 that is attached to a support 256 .
- Particle detector 254 may be comprised of a non-conductive material. In one implementation, particle detector 254 is comprised of CR-39 material.
- Electrodes 260 and 262 may be positioned adjacent to body portion 220 such that an electric field may be created between anode 230 and cathode 232 . In some embodiments, electrodes 260 and 262 may be secured to body portion 220 by an adhesive. Electrodes 260 and 262 are positioned adjacent to the surface of body portion 220 perpendicular to anode 230 and cathode 232 . Electrodes 260 and 262 may be comprised of various conductive materials as recognized by one with ordinary skill in the art, such as copper. As an example, electrodes 260 and 262 may be less than one inch in diameter.
- Electrode 260 may be connected to a regulated high voltage source 264 via wire 266
- electrode 262 may be connected to regulated high voltage source 264 via wire 268
- Wires 266 and 268 may comprise any suitable electrical wire as recognized by one with ordinary skill in the art.
- An example of a voltage source 264 that may be utilized with system 200 is voltage source model 4330, which may be commercially obtained from EMCO. Voltage source 264 may be used to apply 6000V DC (with about 6% AC component) across electrodes 260 and 262 .
- Electrochemical cell 210 includes an electrolytic solution 270 .
- Electrolytic solution 270 may comprise a metallic salt having a first metal that substantially absorbs deuterium when in a reduced state (not shown), and a supporting electrolyte (not shown), each dissolved in heavy water (not shown).
- the reduced deuterium absorbing metal 272 such as palladium, absorbs deuterium 274 .
- deuterium atoms collect on the surface of cathode 232 and enter into the lattice of deuterium absorbing metal 272 when in a reduced state.
- electrolytic solution 270 comprises 20-25 mL solution of 0.03 M palladium chloride and 0.3 M lithium chloride in deuterated water.
- FIG. 7A shows a front view of one side of an embodiment of system 100 , illustrating an embodiment of the cathode 132 .
- cathode 132 is attached to detector 152 .
- cathode 132 consists of a wire 134 .
- wire 134 may be obtained from Aldrich, Au wire part number 326534 or Pt wire part number 349402.
- the cathode may be 0.25 mm in diameter, and be 3 cm in length.
- FIG. 7B illustrates a front view of one side of an embodiment of system 100 , illustrating another embodiment of cathode 132 .
- cathode 132 is formed as a screen 138 .
- Screen 138 may serve to increase the surface area for particle emission.
- Screen 138 may be comprised of various metallic materials, such as Ni, Cu, Ag, and Au.
- a screen 138 commercially available from Delker, part number 3 Ni 5-077, is comprised of nickel, is 3 cm in size, has a thickness of 0.08 mm, and has eyelet dimensions of 1.5 mm ⁇ 2.0 mm.
- FIG. 7C illustrates a front view of one side of an embodiment of system 100 , illustrating another embodiment of cathode 132 . As shown, cathode 132 is attached to detector 152 .
- cathode 132 is formed as a foil 139 .
- Foil 139 may serve to increase the surface area for particle emission.
- Foil 139 may be comprised of various metallic materials, such as Ni, Cu, Ag, and Au.
- a foil 139 commercially available from Aldrich, part number 349267, is 2.5 cm in size and has a thickness of 0.025 mm.
- CR-39 is a polyallydiglycol carbonate polymer that is widely used as a solid state nuclear track dosimeter chip.
- charged particles create along their ionization track a region that is more sensitive to chemical etching than the rest of the bulk. After treatment with an etching agent, tracks remain as holes or pits and their size and shape can be measured.
- CR-39 dosimeter chips are the most efficient detectors for the detection of light particles (alphas or protons).
- a Ni screen or Au/Ag/Pt wire was wrapped around a CR-39 chip and was then used as the substrate for the Pd/D co-deposition. After the Pd was completely plated out, the cell was exposed to either an external electric or magnetic field. The experiment was terminated after two days and the CR-39 chip was etched using standard protocols (6.5 N NaOH at 70° C. for 6-7 hrs). After etching, the chip was examined under a microscope.
- FIGS. 8A and 8B are microphotographs 300 and 400 , respectively, of tracks in CR-39 due to an alpha source.
- the tracks 310 are symmetrical in shape and dark in color.
- the microscope optics are focused inside the pits 410 , as shown in FIG. 8B , bright spots 420 are observed. Tracks have a conical shape. The bright spot 420 is caused by the bottom of the track acting like a lens when the detector is backlit. The dark, symmetrical shapes with bright spots at their centers are diagnostic of nuclear generated tracks.
- FIGS. 8C and 8D show microphotographs 500 and 600 , respectively, of Pd/D co-deposition generated tracks 510 and 610 obtained by focusing the microscope optics on the surface and the bottom of the pits, respectively. It can be seen that the Pd/D co-deposition generated tracks are dark and symmetrical in shape, with bright spots 520 and 620 , respectively, inside them.
- FIG. 9A illustrates a magnified image 700 of a CR-39 taken after a Pd/D co-deposition experiment in a magnetic field in accordance with an embodiment of the system and method for generating particles.
- FIG. 9B illustrates a further magnified image of image 700 .
- the electrode substrate used to create these images is a 0.25 mm diameter Ag wire. Visible inspection of the CR-39 chip showed a cloudy area where the electrode substrate was in close proximity to the CR-39 detector.
- the cloudy area 710 shown in FIG. 9A is approximately 0.5 mm wide and 4.6 mm long. The fact that the cloudy area was only observed where the detector was in close proximity to the cathode indicates that the cathode has caused the cloudiness.
- the 500 ⁇ magnification of the center of the cloudy area shown in FIG. 9B illustrates the presence of numerous overlapping tracks 720 , both large and small. The number of tracks is far more than are observed in laser fusion experiments (typically DD or DT).
- FIGS. 10A and 10B show a side-by-side comparison of features observed when the detector is exposed to depleted U and a detector that has undergone exposure to a Pd/D co-deposition experiment in the presence of an external electric field.
- FIG. 10A illustrates a magnified image 800 of a CR-39 detector exposed to depleted uranium.
- FIG. 10B illustrates a magnified image 900 of a CR-39 detector exposed to a Pd/D co-deposition experiment performed on a Au wire in the presence of a 6000V external electric field in accordance with the disclosed subject matter. Since the features look the same, and since depleted Uranium is giving off alphas, it stands to reason that the features observed for the co-deposition experiment are also due to high energy particles. These particles can be either alphas, protons, or neutrons.
- FIG. 11 illustrates an image 1000 of a CR-39 detector indicating X-ray emission, in accordance with an embodiment of the system and method for generating particles. Instead of tracks, the impression of the electrode substrate is observed in the CR-39 detector which has been caused by the emission of soft X-rays from the cathode.
- the size of the tracks is proportional to the energy of the particle that created the track. It has been observed that the energy of the particles created in these experiments can be controlled by the electrode substrate.
- a light Z material such as Ni
- the particles are small and homogeneous in size, as shown in image 1100 shown in FIG. 12A .
- a higher Z material such as Ag, Au, or Pt
- both large and small particles are observed, as shown in FIGS. 9A , 9 B, 10 B, 12 A, and image 1200 shown in FIG. 12B .
- FIG. 13A shows an SEM image 1300 of the Pd deposit on Au foil that has been exposed to a magnetic field.
- the Lorentz lines of the magnetic field have caused the Pd micro-globules to form star-like features.
- FIGS. 13B-13D show images 1400 , 1500 , and 1600 , respectively, taken of a CR-39 detector after a Pd/D co-deposition experiment in a magnetic field using a Ag wire cathode.
- FIG. 13B shows that the tracks coincide with the Pd deposit indicating that the Pd deposit is the source of the tracks.
- FIGS. 13C and 13D show magnified images of the tracks. The tracks vary in size indicating that particles of different types and energies are being produced.
- Palladium chloride (99%, Aldrich), lithium chloride (analytical grade, Mallinckrodt), deuterated water (99.9% D, Aldrich), 0.25 mm diameter gold wire (99.9%, Aldrich), 0.5 mm diameter silver wire (99.9% Aldrich), 0.25 mm diameter platinum wire (99.9%, Aldrich), nickel screen (Delker, 0.35 mm thick and eyelet dimensions of 3 mm ⁇ 1.9 mm).
- a regulated high voltage source (EMCO model 4330) is used to apply 6000 V DC (and has a ⁇ 6% AC component) across these copper electrodes.
- EMCO model 4330 A regulated high voltage source (EMCO model 4330) is used to apply 6000 V DC (and has a ⁇ 6% AC component) across these copper electrodes.
- the attractive forces between the 1 in ⁇ 1 in ⁇ 0.25 in permanent NdFeB magnets available from Dura Magnetics hold them in place on either side of the cell, as shown in FIGS. 4 and 5 .
- the strength of the magnetic field is on the order of 2000 Gauss.
- the cathodic current is increased to 1 mA for 2 h, 2 mA for 6 h, 5 mA for 24 h, 10 mA for 24 h, 25 mA for 24 h, 50 mA for 24 h, 75 mA for 24 h, and 100 mA for 24 h.
- Table 2 shown below represents a summary of experiments performed to determine if the CR-39 pits were due to contamination or electrolysis.
Abstract
Description
Pd2++2e −Pd0
D2O+e −D0±OD− (Eq. 1)
Once formed, the D0 is either absorbed by the Pd or binds to another D0 to form a deuterium molecule, D2. At standard temperature and pressure, D2 is a gas. The result is that metallic Pd is deposited on the cathode in the presence of evolving D2.
TABLE 1 | ||
Experiment | Field | Result |
Ni screen | None | No pits, see impression of Ni |
screen | ||
Ni screen | E or B | Pits in patches |
Ag wire | None, E, or B | High density of pits |
Au or Pt wire | E or B | High density of pits |
Ag, KCI | E or B | High density of pits |
Ag, H2O | E or B | Pits, less dense than D2O |
Pd wire, no co-dep | E or B | Pits in patches |
CuCl2 in place of PdCl2 | None, E, or B | No pits |
TABLE 2 | |||
Experiment | Result | ||
Place PdCl2 powder on surface of CR-39 | No pits | ||
Immerse CR-39 in PdCl2—LiCl—D2O | No pits | ||
Wrap cathode substrates around CR-39 | No pits | ||
Electrolysis using Ni screen and LiCl—D2O | No pits | ||
Claims (7)
Priority Applications (1)
Application Number | Priority Date | Filing Date | Title |
US11/859,499 US8419919B1 (en) | 2007-03-14 | 2007-09-21 | System and method for generating particles |
Applications Claiming Priority (2)
US91919007P | 2007-03-14 | 2007-03-14 | |
Publications (1)
Publication Number | Publication Date |
US8419919B1 true US8419919B1 (en) | 2013-04-16 |
Family
ID=48049106
Family Applications (1)
Application Number | Title | Priority Date | Filing Date |
US11/859,499 Active 2030-07-23 US8419919B1 (en) | 2007-03-14 | 2007-09-21 | System and method for generating particles |
Country Status (1)
Country | Link |
US (1) | US8419919B1 (en) |
Cited By (7)
Publication number | Priority date | Publication date | Assignee | Title |
US9540960B2 (en) | 2012-03-29 | 2017-01-10 | Lenr Cars Sarl | Low energy nuclear thermoelectric system |
TWI655823B (en) * | 2018-06-15 | 2019-04-01 | 元創綠能科技股份有限公司 | Rechargeable battery and charging method for controlling electron ionization of metal atoms |
CN110192268A (en) * | 2016-10-20 | 2019-08-30 | Ih知识产权控股有限公司 | Method of the plating metal substrate to obtain required surface roughness |
US10465302B2 (en) | 2014-08-07 | 2019-11-05 | Marathon Systems, Inc. | Modular gaseous electrolysis apparatus with actively-cooled header module, co-disposed heat exchanger module and gas manifold modules therefor |
US10480084B1 (en) | 2016-03-03 | 2019-11-19 | Marathon Systems, Inc. | Modular cooling chamber for manifold of gaseous electrolysis apparatus with helium permeable element therefor |
US10841989B2 (en) * | 2018-08-22 | 2020-11-17 | Inovl, Inc. | Gaseous-phase ionizing radiation generator |
US11232880B2 (en) | 2020-06-19 | 2022-01-25 | Inovi, Inc. | Lattice energy conversion device |
Citations (20)
US6248221B1 (en) | 1995-12-26 | 2001-06-19 | Randolph R. Davis | Electrolysis apparatus and electrodes and electrode material therefor |
US20010019594A1 (en) | 1991-09-17 | 2001-09-06 | Swartz Mitchell R. | Method and apparatus to control loaded isotopic fuel within a material |
US20020021777A1 (en) | 1989-06-27 | 2002-02-21 | Swartz Mitchell R. | Method and apparatus to monitor loading using vibration |
US6379512B1 (en) * | 1998-02-11 | 2002-04-30 | Northwest Aluminum Technology | Combination for electrolytic reduction of alumina |
US6444337B1 (en) | 2000-09-26 | 2002-09-03 | Energetics, Inc. | Fuel cell with low cathodic polarization and high power density |
US6562243B2 (en) * | 2001-04-05 | 2003-05-13 | Jonathan Sherman | Synergistic combination of metal ions with an oxidizing agent and algaecide to reduce both required oxidizing agent and microbial sensitivity to fluctuations in oxidizing agent concentration, particularly for swimming pools |
US20030112916A1 (en) | 2000-02-25 | 2003-06-19 | Keeney Franklin W. | Cold nuclear fusion under non-equilibrium conditions |
US20030213696A1 (en) | 2001-05-30 | 2003-11-20 | Energetics Technologies, L.L.C. | Pulsed electrolytic cell |
US20050045482A1 (en) | 2003-08-25 | 2005-03-03 | Storms Edmund K. | Electrolytic heat source |
US20050129160A1 (en) | 2003-12-12 | 2005-06-16 | Robert Indech | Apparatus and method for facilitating nuclear fusion |
US20050236376A1 (en) | 2001-08-13 | 2005-10-27 | Eccles Christopher R | Energy generation |
US20050276366A1 (en) | 1995-05-12 | 2005-12-15 | Electrochemical Innovations, Inc. | Low temperature nuclear fusion |
US20060088138A1 (en) | 2004-04-07 | 2006-04-27 | Andre Jouanneau | Method and apparatus for the generation and the utilization of plasma solid |
US20060153752A1 (en) | 2002-10-11 | 2006-07-13 | Yoshiaki Arata | Hydrogen condensate and method of generating heat therewith |
US20070095823A1 (en) | 2005-10-27 | 2007-05-03 | Sedlmayr Steven R | Microwave nucleon-electron-bonding spin alignment and alteration of materials |
US20070140400A1 (en) | 2005-10-19 | 2007-06-21 | Hodgson John A | Cold fusion apparatus |
US20070206715A1 (en) | 2005-12-29 | 2007-09-06 | Profusion Energy, Inc. | Energy generation apparatus and method |
US20070269688A1 (en) | 2004-05-19 | 2007-11-22 | Sri International | Liquid anode electrochemical cell |
US20070280398A1 (en) | 2005-12-05 | 2007-12-06 | Dardik Irving I | Modified electrodes for low energy nuclear reaction power generators |
US20070286324A1 (en) | 2002-05-18 | 2007-12-13 | Spindletop Corporation | Direct generation of electrical and electromagnetic energy from materials containing deuterium |
2007
- 2007-09-21 US US11/859,499 patent/US8419919B1/en active Active
Patent Citations (22)
US20020009173A1 (en) | 1991-09-17 | 2002-01-24 | Swartz Mitchell R. | Method to control reactions involving isotopic fuel within a material using orthogonal electric-fields |
US20020018538A1 (en) | 1991-09-17 | 2002-02-14 | Swartz Mitchell R. | Method to increase loading of isotopic fuel into a metal |
Non-Patent Citations (33)
Title |
C. Barras. "Neutron tracks revive hopes for cold fusion." NewScientist. Published Mar. 23, 2009. . * |
C. Barras. "Neutron tracks revive hopes for cold fusion." NewScientist. Published Mar. 23, 2009. <http://www.newscientist.com/article/dn16820-neutron-tracks-revive-hopes-for-cold-fusion.html>. * |
D. Cravens. "Factors affecting the success rate of heat generation in CF cells." Fourth International Conference on Cold Fusion. 1993 (no month). pp. 1-14. * |
E. Berger. "Scientist may have cold fusion breakthrough." Houston Chronicle. Published Mar. 23, 2009. <http://www.chron.com/news/nation-world/article/Scientist-may-have-cold-fusion-breakthrough-1728360.php>. * |
F. Celani, A. Spallone, P. Tripodi, A. Petrocchi, D. Di Gioacchino, M. Boutet, P. Marini, V. Di Stefano, M. Diociaiuti, W.Collis. "Reproducible D/Pd ratio >1 and excess heat correlation by 1-muS pulse, high-current electrolysis." Fusion Technology, May 1996, vol. 29. pp. 398-404. * |
F. Celani, A. Spallone, P. Tripodi, A. Petrocchi, D. Di Gioacchino, M. Boutet, P. Marini, V. Di Stefano, M. Diociaiuti, W.Collis. "Reproducible D/Pd ratio >1 and excess heat correlation by 1-μS pulse, high-current electrolysis." Fusion Technology, May 1996, vol. 29. pp. 398-404. * |
F. H. Seguin, et al., "Spectrometry of charged particles from inertial-confinement-fusion Plasmas", Review of Scientific Instruments, vol. 74, No. 2, 2003. |
G.W. Phillips, et al., "Neutron Spectrometry Using CR-39 Track Etch Detectors", 4th International Solid State Dosimetry Conference, New Haven, CT, Jun. 28, 2004. |
G.W. Phillips, et al., Neutron Spectrometry Using CR-39 Track Etch Detectors, Radiation Protection Dosimetry, vol. 120, No. 1-4, pp. 457-460, 2006. |
J. O'M. Bockris, R. Sundaresan, Z. Minevski, D. Letts. "Triggering of heat and sub-surface changes in Pd-D Systems." The Fourth International Conference on Cold Fusion. Transacations of Fusion Technology, Dec. 1994. vol. 25, No. 4T. p. 267. * |
J.O'M. Bockris, R. Sundaresan, D. Letts, Z. Minevski. "Triggering of heat and sub-surface changes in Pd-D systems." Proceeding: Fourth International Conference on Cold Fusion. vol. 2: Calrimetry & Materials Papers. Jul. 30, 1994. pp. 1-1 to 1-46. * |
Mosier-Boss, P.A. et al., "Use of CR-39 in Pd/D Co-Deposition Experiments", The European Physical Journal-Applied Physics, Dec. 13, 2007, pp. 293-303, v. 40, EDP Sciences. |
P. Hagelstein. "Summary of the thrid annual conference on cold fusion." Feb. 16, 1993. pp. 1-40. * |
R. Van Noorden. "Cold fusion back on the menu." Royal Society of Chemistry (RSC). Published Mar. 22, 2007. . * |
R. Van Noorden. "Cold fusion back on the menu." Royal Society of Chemistry (RSC). Published Mar. 22, 2007. <http://www.rsc.org/chemistryworld/News/2007/March/22030701.asp>. * |
Szpak, S. and P.A. Mosier-Boss, "On the behavior of the cathodically polarized Pd/D system: a response to Vigier's comments", Physics Letters A, 1996, v.221, pp. 141-143. |
Szpak, S. and P.A. Mosier-Boss, and F.E. Gordon, "Further evidence of nuclear reactions in the Pd/D lattice: Emission of charged particles", Naturwissenschaften, 2007, v. 94, No. 6, pp. 511-514. |
Szpak, S. and P.A. Mosier-Boss, and F.E. Gordon, "Precursors and the fusion reactions in polarized Pd/D-D2O system: effect of an external electric field", Condensed Matter Nuclear Science, Proceedings of the International Conference on Cold Fusion, 11th, Marseilles, France, Oct. 31-Nov. 5, 2004, 2006: pp. 359-373. |
Szpak, S., et al., "Absorption of deuterium in palladium rods: model vs. experiment", Journal of Electroanalytical Chemistry, 1994. v.365, No. 1-2, pp. 275-281. |
Szpak, S., et al., Charging of the palladium/hydrogen or deuterium (Pd/nH) system: role of the interphase, Journal of Electroanalytical Chemistry, 1992, v.337(1-2), pp. 147-163. |
Szpak, S., Mosier-Boss, P.A., "Nuclear and Thermal Events Associated With Pd + D Codeposition", J. New Energy, 1996, p. 54, vol. 1, No. 3. |
Szpak, S., Mosier-Boss, P.A., Boss, R.D., Smith, J.J., "On the Behavior of the PD/D System: Evidence for Tritium Production", Fusion Technol., 1998, p. 38, vol. 33. |
Szpak, S., Mosier-Boss, P.A., Gordon, F.E., "Precursors and the Fusion Reactions in Polarized Pd/D-D20 System: Effect of an External Electric Field", 11th Int. Conf. on Condensed Matter Nuclear Science, 2004, Marsailles, France. |
Szpak, S., Mosier-Boss, P.A., J. Dea, Gordon, F.E, "Polarized D/Pd-D20 System: Hot Spots and Mini-Explosions", 10th Int. Conf. on Cold Fusion, Cambridge, MA, 2003. |
Szpak, S., Mosier-Boss, P.A., Miles, M.H., Fleischmann, M., "Thermal Behavior of Polarized Pd/D Electrodes Prepared by Co-Deposition", Thermochimica Acta, 2004, pp. 101-107, vol. 410, Elsevier B.V. |
Szpak, S., Mosier-Boss, P.A., Smith, J.J., "On the Behavior of the Cathodically Polarized Pd/D System: Search for Emanating Radiation", Physics Letters A, Jan. 22, 1996, pp. 382-390, vol. 210, Elsevier Science B.V. |
Szpak, S., Mosier-Boss, P.A., Young, C., Gordon, F.E., "Evidence of Nuclear Reactions in the Pd Lattice", Naturwissenschaften, Jul. 29, 2005, pp. 394-397, Springer-Verlag. |
Szpak, S., Mosier-Boss, P.A., Young, C., Gordon, F.E., "The Effect of an External Electric Field on Surface Morphology of Co-Deposited Pd/D films", J. of Electroanalytical Chemistry, May 23, 2005, pp. 284-290, vol. 580. |
Szpak, S., P.A. Mosier-Boss, and J.J. Smith, "Comments on methodology of excess tritium determination", Frontiers Science Series, 1993, v.4, pp. 515-518. |
Szpak, S., P.A. Mosier-Boss, and J.J. Smith, "On the behavior of palladium deposited in the presence of evolving deuterium", Journal of Electroanalytical Chemistry and Interfacial Electrochemistry, 1991, v.302(1-2), pp. 255-260. |
Szpak, S., P.A. Mosier-Boss, and J.J. Smith, "Reliable procedure for the initiation of the Fleischmann-Pons effect", Conference Proceedings-Italian Physical Society, 1991. v. 33, pp. 87-91. |
US Department of Energy. "Report of the review of low energy nuclear reactions." Published Dec. 1, 2004. . * |
US Department of Energy. "Report of the review of low energy nuclear reactions." Published Dec. 1, 2004. <http://lenr-canr.org/acrobat/DOEreportofth.pdf>. * |
Cited By (9)
EP3529827A4 (en) * | 2016-10-20 | 2020-09-09 | IH IP Holdings Limited | Method of plating a metallic substrate to achieve a desired surface coarseness |
WO2021034865A1 (en) * | 2018-08-22 | 2021-02-25 | GORDON, Frank, E. | Gaseous-phase ionizing radiation generator |
Similar Documents
Publication | Publication Date | Title |
US8419919B1 (en) | System and method for generating particles | |
Mosier-Boss et al. | Use of CR-39 in Pd/D co-deposition experiments | |
WO1990013125A1 (en) | Piezonuclear fusion | |
US20220328208A1 (en) | PRODUCTION METHOD OF 225Ac | |
Ikegami et al. | Structure of platinum nuclei (i) new decay scheme of Au196 | |
Zeisler et al. | Production of 64 Cu on the Sherbrooke TR-PET cyclotron | |
Mosier-Boss et al. | Characterization of tracks in CR-39 detectors obtained as a result of Pd/D Co-deposition | |
JP2004507713A (en) | Cold fusion under nonequilibrium conditions | |
US10841989B2 (en) | Gaseous-phase ionizing radiation generator | |
Wang et al. | Electrochemical co-deposition of Ni–Gd2O3 for composite thin targets preparation: Production of 155Tb as a case study | |
Mosier-Boss et al. | Energetic particle emission in Pd/D co-deposition: an undergraduate research project to replicate a new scientific phenomenon | |
Frey et al. | Analysis of electrodeposited nickel-iron alloy film composition using particle-induced X-ray emission | |
Cheng et al. | Preparation of 68Ge/68Ga generator with a binary Ga/Ag electrodepositions as solid target | |
Dash et al. | On the application of electrochemical techniques for the preparation of 57Co source core, encapsulation and quality evaluation for radiometric assay of nuclear fuel rods | |
Saliba-Silva et al. | Uranium briquettes for irradiation target | |
Saliba-Silva et al. | Uranium electrodeposition for irradiation targets | |
Sounalet et al. | Manufacture of Tl targets by electrodeposition for the study of excitation functions of 203Pb | |
Knights et al. | Gas and copper purity investigations for NEWS-G | |
Saliba-Silva et al. | Nickel electrodeposition over powder compact for irradiation target | |
Driscoll et al. | Issues related to reproducibility in a CMNS experiment | |
Rajan et al. | Electromigration approach to verify cold fusion effects | |
EP3859050A1 (en) | Electrolysis devices using ionizing radiation and related methods | |
Mosier-Boss et al. | Interpreting CR-39 Detectors used in Pd/D Co-deposition: Nuclear Generated Tracks or Artifacts? | |
Beronius et al. | Electrodeposition of'point'Cu 125 I roentgen sources | |
Ulmer | Application of Ionizing Radiation for the Enhancement of Hydrogen Yield in Electrolytic Water Decomposition |
Legal Events
Date | Code | Title | Description |
AS | Assignment |
Owner name: JWK INTERNATIONAL CORPORATION, VIRGINIA Free format text: ASSIGNMENT OF ASSIGNORS INTEREST;ASSIGNOR:FORSLEY, LAWRENCE PARKER GALLOWAY;REEL/FRAME:030213/0096 Effective date: 20130123 |
AS | Assignment |
Owner name: JWK INTERNATIONAL CORPORATION, VIRGINIA Free format text: ASSIGNMENT OF ASSIGNORS INTEREST;ASSIGNOR:FORSLEY, LAWRENCE PARKER GALLOWAY;REEL/FRAME:030212/0979 Effective date: 20130123 |
STCF | Information on status: patent grant |
Free format text: PATENTED CASE |
FPAY | Fee payment |
Year of fee payment: 4 |
FEPP | Fee payment procedure |
Free format text: MAINTENANCE FEE REMINDER MAILED (ORIGINAL EVENT CODE: REM.); ENTITY STATUS OF PATENT OWNER: LARGE ENTITY |
Free format text: ENTITY STATUS SET TO SMALL (ORIGINAL EVENT CODE: SMAL); ENTITY STATUS OF PATENT OWNER: SMALL ENTITY Free format text: 7.5 YR SURCHARGE - LATE PMT W/IN 6 MO, SMALL ENTITY (ORIGINAL EVENT CODE: M2555); ENTITY STATUS OF PATENT OWNER: SMALL ENTITY |
MAFP | Maintenance fee payment |
Free format text: PAYMENT OF MAINTENANCE FEE, 8TH YR, SMALL ENTITY (ORIGINAL EVENT CODE: M2552); ENTITY STATUS OF PATENT OWNER: SMALL ENTITY Year of fee payment: 8 |
